how to make mormals to a specified range.
   4784   7   1
how to make point's normal dircect to the reference normal and offset in a certain angle?
https://vimeo.com/user3971456/videos [vimeo.com]
you can calculate the length of the vector either in VOPs or with an hscript expression, or however you want to do it:
length (float x, float y, float z)
when you have length A and B you can subtract them to get the difference, which you then can add to each component of the shorter vector, that should give you matching lengths.
cheers,
Manuel
http://vimeo.com/user2522760 [vimeo.com]
http://stormbornvfx.com/ [stormbornvfx.com]
Manuel Tausch
asnowcappedromance
cheers,
Manuel
thank you, but i dont know weather i dont understand your idea or i have not cleared my mean.
i want set points' normal as the referenced normal, but with some rand offset
Set your normals equal to the ‘target’ normal, and add your desired offset.
Easy Peasy.
G
keyframe
Easy Peasy.
G
ops: sorry for the fool question
here is a way ..
activate “vopsop1” and play with both parameters .
you can manipulate values further with some noise , etc ..
the “fitrange VOP” could be useful too .
hope this helps .
( H11 file )
normalzRandomWithinRange.hip (98.9 KB)
except the things that cannot be seen , nothing is like it seems .
If you already have an offset between ref normal, and now want to fit this offset to a certain range,you can compute its anglebetween, and fit range ,then use this resault angle to rotate it ,axis is the cross product.
if not, are you just want a random resault around ref normal? generate a random vector,cross production make it orthogonal with refnormal,and use it to rotate ref normal a random angle
Or use sin(rad)*normalize(randomOrthogonal)+cos(rad)*normalize(refnormal)instead of rotate().
that's what's i need
谢谢小林
