Hi
I created a coin in the houdini.assign Mantra Surface Material(with Light & Object Reflection) to it.
I created a Mantra Node (Pixel Samples : 6 6 and image Size 1280 * 720 )
. but when I render the scene , Houdini Render some frames (for example 1 to 10 ) and after frame 10 Mantra Node Stoped with error.
when I take Mantra Node Info by MMB click on it I take below error :
Error : Command Exit Code : -1073741819
Why ?
Mantra Error -1073741819
3780 5 1-
- Sadjad Rabiee
- 1391 posts
- reelinspirations
- 177 posts
- edward
- 7969 posts
Sounds like you're running into a multithreading bug causing to Mantra to crash. One thing to try is to run it single threaded with “mantra -j1” as the command. Of course, this will slow the render of each frame by the number cores you have. If it always crashes after a max number of frames but not in single threaded mode, then you've found a multi-threading bug and should submit your complete files with reproducible steps.
- Sadjad Rabiee
- 1391 posts
- dupengfei1109
- 3 posts
reelinspirations
I am having the exact same error code. It's a project I have rendered before, but now it's giving me that code.
It will render for 20 or 30 frames, then give me the error.
Anyone find a reason or solution?
Hi I just saw your post
Error Code: Command Exit Code: -1073741819
I have the same problem as you, do you know how to solve it now, it's annoying me
thank you very much
https://www.sidefx.com/forum/topic/25961/ [www.sidefx.com]
- dupengfei1109
- 3 posts
