How to save render passes?
3351 2 2- miklem
- 43 posts
- claudio_101
- 121 posts
On the properties of your mantra node go to Properties/Output and click on the plus button of “Extra Image Planes”.
In the VEX variable you type your shader attribute or just click on the dropdown list to select one if using a default shader.
To give the image plane a different name and path check the “Different file” option. But be sure to change the “Output picture” path from ip to path/filename, otherwise the “Different file” option will be greyed out.
Available for new projects
- miklem
- 43 posts
