Bridging?
   9193   7   3
Bridging, connecting, sewing, ……..whatever you want to call it. Is there a way to do this with facing polygons in houdini?
http://www.m2estudios.com/images/PolySew/ExternalBridging.gif [m2estudios.com]
ps. lofting and skinning didnt seem work……
soho vfx
yep !
You can use for example, PolyLoft or PolyKnit SOPs
Julien
Take 2 boxes and put them side by side………
Now how do you connect the 2 facing polygons without deleting them and manually Knitting the boxes togethertogether? Because im just not getting results that are useful. If I get something its usually a mess. I must be doing it wrong. :cry:
soho vfx
“PolyExtrude” the four edges of one box towards the other box.
“Merge” both boxes and than “Fuse” them.
The Things I Do For Love!
Nice try but no cigar…
That doesnt work either because it leaves the facing polygons inside and requires deletion. Further more this is only easy when you have 2 identical boxes lined up side by side. If one of them was push down diagonally and rotated a bit this would become a mess. :wink:
soho vfx
Hi Warren!
One quick fix…Copy the facing polygons, polyknit them, delete the copies and merge the
polyknited shape to your original boxes.
Cheers!
silvina
Thats what I did……..but thats not bridging!
It should be as simple as selecting the 2 polygons and clicking bridge. It is common tool that is used for volume/box modeling.
http://www.softimage.com/Community/Xsi/Events/nab2001/media/video/CREATE/Polygonals_Tools_B.html [softimage.com]
(sorry its quicktime….)
soho vfx
You can select the two polygons and append a Skin SOP. Maybe you'll need to use a Primitive SOP before, with the Face/Hull-> Vertex->shift option, to shift the vertices on one poly, in order to avoid twisted skinning.
Dragos
Dragos Stefan
producer + director @ www.dsg.ro
www.dragosstefan.ro
