I am desperately looking for a basic scene or tutorial to better understand the relationship between composting and 3D.
Practically I would like: - to apply basic filters on an image and to be able to use it as a background image when rendering a 3D scene - to be able to use this filtered image as a texture
In the other way I would like to get the output of a camera (the real output, not a generated images sequence) into the compositor and to apply some filters on it.
It may sound basic but I have a hard time to find tutorials on that.
By browsing in the documentation from them i aslo found this interesting page: Mantra render node (http://www.sidefx.com/docs/houdini12.0/nodes/out/ifd [sidefx.com]), with several examples including one called Rop_Fetch_Example1 (Fetch example), which is quite simple and nice to start with.
Things are still a bit tricking though and I still have troubles to understand with I sometimes don't get a visual result. I'll play some more and come back with a scene if I still have some troubles.
In spite of many tries I still have troubles with the nodes you suggested
- I failed to make the Render COP node work:
Whatever I do the node says that it cannot read the input files.
Here is a basic scene. Could you please have a look at it and tell me if I do something wrong?
As the documentation says: “This node currently only works with output drivers that produce .pic format files.” I start wondering if it supports .picnc files…
- Unfortunately I also failed to make the ‘op’ function work. (I know it sounds a lot at the same time, but honestly I would have expected Houdini to be more intuitive and documented sometimes…). I used a File node in the Img network to get the 3D renderings (with the expression opout/mantra1 to get the output) and plugged it into a composite. Here the File node says 'Cannot find file opout/mantra1. … Although I followed the documentation samples. :?
Guess, you're right. I suppose, your first approch doesn't work, because you're on a non-commercial license. Just double-checked it with Hmaster - no problem here…
You're second approch doesn't work. The op-syntax doesn't trigger renders. Use it instead to access eg. the cop-out from SHOPs or SOPs.
Could be, that you have to render files to disk first, when you're on apprentice. I didn't know that. But, documentation on what's supported and what not with non-commercial licenses always seemed to be not very comprehensive in my eyes.
