Strange houdini problem
   12440   13   0
My computer does not know where a problem.Open houdini when the total of the following content.Hope that teachers will help me.Thank you.
谢谢
my SVGIcons.cache' corrupted?
warning: failed to load ‘VIEW_flat_wireframe.svg’
‘CUsers/linshi/Documents/houdini12.0/config/Icons/SVGIcons.cache’ corrupted?
‘CUsers/linshi/Documents/houdini12.0/config/Icons/SVGIcons.cache’ corrupted? :shock:
I have a simple question, how fast can find I made ​​a post in the forum, because my English is poor.
Are you running Apprentice or the Commercial version?
Peter Bowmar
____________
I get this sometimes with FX(Master) license.
daniel bukovec | senior fx td | weta digital
qLib -- http://qlab.github.io/qLib/ [qlab.github.io]
I'm sporadically encountering this, Houdini FX 12.5.* , Win7. I've deleted the Icon cache a few times already. Haven't yet figured out what triggers it.
Very grateful to you for your answer, which gave me great help.
12.5.413 looks like it should hit the spot:
Houdini 12.5.413: Fixed a bug where running multiple Houdini sessions would either crash Houdini or produce icon cache corruption warnings.
Houdini 12.5.413: A corrupted icon cache should no longer cause Houdini to crash, though a corrupted icon will not display properly.
Anyone else still having icons issue? I do, I a using build 371.
Any solution?
https://vimeo.com/user2163076 [vimeo.com]
Did you see Eetu's post?
Peter Bowmar
____________
Yes I did but I can't install a newer build now, I was hoping that there was a solution for my case for now.
Well, unfortunately, the only solution is a newer build…
Peter Bowmar
____________
Thanks guys!
I do not understand why I have to lose my time trying to solve a situation with “icons”.
Edited by - April 24, 2016 20:06:42
Well, if you're paying for it then you should likely email Support.
Also, if you've ever used professional software before you'll know that there is no software that is free of bugs. The more complex the software the more chance of a bug.
Peter B
Peter Bowmar
____________
Have you tried just deleting the mentiond files? I did, houdini recreated it, and now works like a champ.
