i have a node with some primitives and some primitive attributes named corner_1 to corner_N. the amount of corners is variable and depends on whether the endpoints overlap or not.
now i want that the primitiv is attached to a group called corner_X if the value in the corresponding attribute is 1
is that somehow possible?
greetings
group based on primitiv attributes
2534 3 1- jan_hh
- 4 posts
- asnowcappedromance
- 512 posts
Why don't you do the grouping in that python SOP that is plugged
into the group node? If you're looking for a node based approach,
put the group SOP into a foreach SOP, loop N times over your primitives
and stamp the loop iteration onto the group name parameter, use the
stamp() expression in the group's expression field as well!
Best,
Manu
Best,
Manu
- jan_hh
- 4 posts
- 512 posts
that was some previous version of houdini where grouping wasn't possible, with Houdini 12 you can definitely do it.
http://www.sidefx.com/docs/houdini12.0/hom/hou/PrimGroup [sidefx.com]
