hello I had a question about how these 2 differ from one another when use to deform geo.
I watched the CmiVFX Vex volume 1 and follow the twist deform formula, however I notice something. when Done in VopSop my deformation isn't as clean than when it's done in Vex. could someone explain to me why it does that?
I had thought the 2 were the same code.
plus on another question is why Vopsop vs Vex. performance?
thank you for any help.
Vex VopSop question.
4419 2 3- enderki
- 7 posts
- massta
- 61 posts
Sounds like a good question. I've started the same learning video but haven't gotten that far. I'm enjoying the VOP SOP at the moment and have this thread going right now:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=27162 [sidefx.com]
I guess the vop sop is a local vex op, where as vex is independent of sops.
~Shawn
~Shawn
Touch Designer User
- Alanw
- 320 posts
enderki
Are you referring to the difference between implementing VEX in SOP's vs. a Displacement shader rendered with Mantra ?
If this is the case, the rendered result is much smoother since Mantra dices the geometry to a very fine level of detail, where SOP's is typically not using near as many polygons. (More info here [sidefx.com])
You can put down a subdivide SOP and crank up the levels until your result more closely resembles Mantra's output, but take caution not to set it too high, or things will get really slow.
A VOP SOP is processed in real time as you are working in Houdini, so it's going to be much slower than Mantra.
Hope that helps
-Alan
