Randomizing copies on a DOP Network
   2285   2   0
Hi Everyone, i am trying to reproduce a shot i saw in a reel, several gummi bears bouncing in a floor.
In the scene i did, I made a DOP network for a single object (a cylinder with squishy object attributes to be replaced with a Gummi Bear model later and a ground), after that i put a copy node (putting a stamp parameter) with a grid as template, and a timeshift node (pointing the stamp parameter to avoid all copies fall at the same time).
But I don't know how to randomize each copied object's rotation.
I uploaded the hip file if you wanna check it and suggest me some solution. Any advice will be appreciated.
Thanx in advance!
bouncings.hipnc (143.0 KB)
To build in variation you should be using that handy DOP variable $OBJID !
Rob
Gone fishing
circusmonkey
Rob
Hi Rob, where i have to put that variable?
