White square instead of icons
   8072   8   2
Hi there, I have some problems with icons in houdini, the first screen loads ok, but as soon as I create an object or load a scene, it fails to load any icon not previously shown on the inital screen. This is the error message on the shell:
  • /opt/hfs12.1.125/hsvg/hsvg: line 7: /hsvg/hsvg-bin: No such file or directory
    It repeats itself for every missed icon. I already tried to delete the cache in:
    ~/houdini12.1/config/Icons/SVGIcons.cache
    I'm stuck with this error, can't solve this.
    The $HFS/hsvg/hsvg script is pointing to a valid hsvg-bin file.
    I am using hfs12.1.125, either houdini or houdinifx with aprrentice license on a openSuSE 12.1 x86_64bits with latest nvidia proprietary driver for a 560gtx card.
Luc de Paula
Hi there, updated to a daily build (hfs12.1.146) but the issue persists.
I also get this message in the lower part of screen (in this case, just creating a sphere):
Unable to find file “/tmp/SOP_sphere24x24.png : No such file or directory”. Unrecognized file type “/tmp/SOP_sphere24x24.png : No such file or directory”.
Executing ./installDesktopItems.py brings the following error:
./installDesktopItems.py: line 8: syntax error near unexpected token `('
./installDesktopItems.py: line 8: `SRC = os.path.dirname( sys.argv )'
Are they related? Any tips? By the way, I am using an apprentice license, if this is the wrong forum to post it, I apologize.
Luc de Paula
Hi
Check this thread:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=25067&highlight= [sidefx.com]
Cheers
Toronto - ON
Hi Rafaels, the link does not exist. I gess I came back too late
By the way, happy holidays for you.
P.s.: About the missing icons problem… Is it a permission problem? Something during install?
Luc de Paula
Thank you, I did see that post and tried that before. Just downloaded latest version and tried again! Error remains if using my user. If I open houdini as root it works flawless but if I run houdini without root privilegies I get the same errors. I also copied the cache from the root user to my user (and changed ownership, of course), the icons I previously loaded as root show up, the others do not. At the console window just under the timeline i get messages like this:
unable to find file /tmp/SOP_platonic24x24.png
I am pretty sure it is a permission problem, just need to figure out where. By the way, giving owner privilegies to my user over the instalation dir doesn't help.
Luc de Paula
I ran across this possible solution: http://askubuntu.com/questions/71641/houdini-apprentice-not-showing-icons [askubuntu.com] but it didn't work.
Checking this old thread http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&p=81709&sid=4ff4ea6e03ea986f16d0bf406c7f6edf [sidefx.com] gave me some speed in the viewport but the same problem with icons. I also deleted the libs under hsvg (not the binaries), and ldd hsvg returns not a dynamic executable
As soon as I click on an icon not previously loaded I get this error in shell: /opt/hfs12.1.185/hsvg/hsvg: line 7: /hsvg/hsvg-bin: No such file or directory.
This is the output of gcc -v:
gcc version 4.7.1 20120723 (SUSE Linux)
Running out of ideas here… :?
Luc de Paula
You need to run ldd on hsvg-bin, not hsvg. Which distro are you running?
PS. old post that might help with debugging http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&p=82774&highlight=#82774 [sidefx.com]
I'm having this problem too, on OpenSuse 12.2, houdini 12.1.185 :
ldd hsvg-bin
linux-vdso.so.1 (0x00007fff339ff000)
librsvg-2.so.2 => /usr/lib64/librsvg-2.so.2 (0x00007faa36efa000)
libgio-2.0.so.0 => /usr/lib64/libgio-2.0.so.0 (0x00007faa36ba9000)
libgdk_pixbuf-2.0.so.0 => /usr/lib64/libgdk_pixbuf-2.0.so.0 (0x00007faa36989000)
libm.so.6 => /lib64/libm.so.6 (0x00007faa36692000)
libgobject-2.0.so.0 => /usr/lib64/libgobject-2.0.so.0 (0x00007faa36444000)
libgmodule-2.0.so.0 => /usr/lib64/libgmodule-2.0.so.0 (0x00007faa36240000)
libgthread-2.0.so.0 => /usr/lib64/libgthread-2.0.so.0 (0x00007faa3603e000)
librt.so.1 => /lib64/librt.so.1 (0x00007faa35e36000)
libglib-2.0.so.0 => /usr/lib64/libglib-2.0.so.0 (0x00007faa35b3f000)
libcairo.so.2 => /usr/lib64/libcairo.so.2 (0x00007faa35847000)
libpng12.so.0 => /usr/lib64/libpng12.so.0 (0x00007faa3561d000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007faa35401000)
libc.so.6 => /lib64/libc.so.6 (0x00007faa3505c000)
libpangocairo-1.0.so.0 => /usr/lib64/libpangocairo-1.0.so.0 (0x00007faa34e4f000)
libpango-1.0.so.0 => /usr/lib64/libpango-1.0.so.0 (0x00007faa34c03000)
libcroco-0.6.so.3 => /usr/lib64/libcroco-0.6.so.3 (0x00007faa349c8000)
libxml2.so.2 => /usr/lib64/libxml2.so.2 (0x00007faa3466a000)
libz.so.1 => /lib64/libz.so.1 (0x00007faa34454000)
libselinux.so.1 => /lib64/libselinux.so.1 (0x00007faa34236000)
libresolv.so.2 => /lib64/libresolv.so.2 (0x00007faa3401f000)
libffi.so.4 => /usr/lib64/libffi.so.4 (0x00007faa33e17000)
libdl.so.2 => /lib64/libdl.so.2 (0x00007faa33c13000)
/lib64/ld-linux-x86-64.so.2 (0x00007faa3712f000)
libpcre.so.1 => /usr/lib64/libpcre.so.1 (0x00007faa339b9000)
libpixman-1.so.0 => /usr/lib64/libpixman-1.so.0 (0x00007faa33732000)
libfontconfig.so.1 => /usr/lib64/libfontconfig.so.1 (0x00007faa334fb000)
libfreetype.so.6 => /usr/lib64/libfreetype.so.6 (0x00007faa3326e000)
libpng14.so.14 => /usr/lib64/libpng14.so.14 (0x00007faa33045000)
libxcb-shm.so.0 => /usr/lib64/libxcb-shm.so.0 (0x00007faa32e42000)
libxcb-render.so.0 => /usr/lib64/libxcb-render.so.0 (0x00007faa32c38000)
libxcb.so.1 => /usr/lib64/libxcb.so.1 (0x00007faa32a18000)
libXrender.so.1 => /usr/lib64/libXrender.so.1 (0x00007faa3280e000)
libX11.so.6 => /usr/lib64/libX11.so.6 (0x00007faa324d2000)
libpangoft2-1.0.so.0 => /usr/lib64/libpangoft2-1.0.so.0 (0x00007faa322a6000)
liblzma.so.5 => /usr/lib64/liblzma.so.5 (0x00007faa32080000)
libexpat.so.1 => /usr/lib64/libexpat.so.1 (0x00007faa31e56000)
libXau.so.6 => /usr/lib64/libXau.so.6 (0x00007faa31c52000)
also on a seperate issue, though might be related, I'm getting some drawing issues with voxel previews (image attached)
