So my problem is I'm trying to make a wood splinters in Houdini. My current set up is.
Geometry
Transform
Scatter
Fracture Points
Fracture
Transform
But my problem arises when I try to put that information into my DOP pre fractured. Where I'm currently getting no fracturing and the scale is incorrect.
Sorry if this a really nooby question, I'm primary a Maya user but I'm trying to expand.
Wood Splinter
5979 8 1- joshcurtis1991
- 3 posts
- zdimaria
- 390 posts
- joshcurtis1991
- 3 posts
- zdimaria
- 390 posts
- joshcurtis1991
- 3 posts
- zdimaria
- 390 posts
http://www.sidefx.com/docs/houdini12.1/io/geo [sidefx.com]
you can use a file sop or a rop out driver
- sl0throp
- 258 posts
While you can find sequence importers for both .bgeo and .obj for Maya it is slow and clunky- a much better option would be to use .FBX or Alembic which works really well in most cases. You should use an attributePromote to promote your points to vertices with a facetSop to give the geometry good normals. You can change your normals in Maya but usually have to unlock them.
- goldfarb
- 3464 posts
- mattv
- 21 posts
sl0throp
If your mesh came in from Maya originally though, I'm guessing a facetSop is going to mess up all the original normals, correct?
