How to create a vortex field?
16112 4 5- JasonH
- 25 posts
- vleermeneer
- 245 posts
- Sadjad Rabiee
- 1391 posts
You should use a curve for vortex force !
In the DopNetwork append a “SOP Geometry” and create a simple curve and “Vortex Force Attributes” in the “SOP Geometry” .
don't forget to turn off “Use External SOP” parameter in the SOP Geometry (of Course you can create curve on the obj level and use External SOP)
Connect Sop Geometry to second input of the Vortex Force and press Play !
just to define radius of the Vortex Force you should set keyframe for “Radius” parameter on the “Vortex Force Attributes”
I made a simple scene for you
- JasonH
- 25 posts
- MartinCoetzee
- 1 posts
