Houdini Points not displaying properly
   5276   3   1
I have gone through multiple tutorials, and at certain points, when the time comes to view my points in my scene, they don't display properly. Within the tutorial, the points appear white as soon as, for example, a scatter node is viewed. However, this doesn't work for me. The only way for me to view the points is by displaying points in the viewport. Then the points are displayed as blue. By default, within the tutorial, it appears that points should be viewable as white. If you have heard anything about this issue, please let me know.
-Joseph
could be just the viewport issue. try switching from H11 to GL3.2
Add an “Add” sop after the scatter. then under Particles set “Add Particle System”.
Or like mentioned switch the H11 viewport and it should show the points.
cheers.
Thanks for the help! Adding an Add sop and selecting Add Particle Network resolved my problem. Thanks for the help guys!
-Joseph
