RBD state and glue per OBJ
   Views 2895   Replies 1   Subscribers 2
heya, I'm trying to set internal glue strength on my shattered object and I'm having difficulties.
scenario: frame 10 and only at frame 10 I have a fieldforce that “kicks” my shattered window.
if I don't use the RBD state my window gets shattered as normal, entirely.
what I want is having the border of my glass to stick with the window, and I thought about using the RBD state and set a “glue” attrib in SOP.
I'm using the
prim(“$DOPNET:$OBJID/Geometry”, 0, “glue”, 0)
expression in my RBD state DOP … but when I use such node I have a weird behavior: at frame 10 the window get shattered and objects move, but then at frame 11 they all go back to their initial position.
I also get a “bad reference” warning, so I'm guessing the expression is wrong.
I can try and provide a sample scene if needed.
any help is really appreciated!
thankie.
JcN
VisualCortexLab Ltd :: www.visualcortexlab.com
Can you upload your scene file?
