So I upgraded to 12.10 and now I'm getting
Warning: program compiled against libxml 208 using older 207
I presume this has something to do with the Orbolt stuff….
anyways…did I make a big mistake upgrading…
Jim
ubuntu 12.10
7999 5 0- jimbojones
- 27 posts
- protozoan
- 1717 posts
- jimbojones
- 27 posts
- jimbojones
- 27 posts
- matsbtegner
- 38 posts
I've seen the same warning message when launching H12.5 under Slackware 14.0 as well. I believe it's related to the packages GConf2 and libxml. If you upgrade to libxml 2.8.0 or later and recompile GConf2 3.2.6 it will go away.
If you'd like to cultivate insomnia,
Bed down with a pretty girl.
Amor vincit omnia.
Amor vincit omnia.
- ben simons
- 387 posts
Houdini running in: Gentoo Linux: 3.10.25-gentoo x86_64
I've recently seen something similar in Houdini 13.0.314
- $ houdini
Warning: program compiled against libxml 209 using older 208
and with Houdini 12.5.483
$ houdini
./hbrowser-bin: /opt/hfs12.5.483/python/lib/libz.so.1: version `ZLIB_1.2.3.4' not found (required by /usr/lib/libpng16.so.16)
Warning: program compiled against libxml 209 using older 207
Gentoo is linux built from source.
libxml has been compiled with the following flags:
# emerge -pv libxml2
These are the packages that would be merged, in order:
Calculating dependencies… done!
dev-libs/libxml2-2.9.1-r1:2 USE=“icu ipv6 python readline -debug -examples -lzma -static-libs {-test}” PYTHON_TARGETS=“python2_7 python3_3 -python2_6 -python3_2” 0 kB
This gentoo “emerge” command indicates libxml2 (version 2-2.9.1) has been compiled for python targets 2.7 and 3.3 (and not 2.6 or 3.2)
Following a post by Neil78 http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=29185&highlight=libxml [sidefx.com] referencing a Wolfwood post I tried setting houdini environment vars:
$ export HOUDINI_PYTHON_BIN=/opt/hfs13.0.314/python/bin/python2.7
$ export HOUDINI_PYTHON_LIB=/opt/hfs13.0.314/python/lib/libpython2.7.so
$ houdini
$ Warning: program compiled against libxml 209 using older 208
still there. Same is true if HOUDINI_PYTHON var's are set to python2.6
Checking what libxml is installed with houdini:
$ cd /opt/hfs13.0.314
$ find . -iname ‘*libxml*’
./python/lib/libxml2.so.2.8.0
./dsolib/libxml2.so.2.8.0
./dsolib/libcollada_LIBXMLPlugin.so
./dsolib/libxml2.so
./mozilla/components/libxmlextras.so
./toolkit/include/libxml
./houdini/help/licenses/libxml2.html
./houdini/help/licenses/libxml2.txt
./hsvg/libxml2.so.2.8.0
./hsvg/libxml2.so.2
./hsvg/libxml2.so
It looks like the libxml shipped with Houdini 13.0.314 is “208” not “209” (?)
b.
''You're always doing this: reducing it to science. Why can't it be real?'' – Jackie Tyler
