OpenCL problem in PyroFX
   Views 3509   Replies 2   Subscribers 0
I'm sorry for my mistake
I tried more time and notice, even use tow card the result is not always correctly. maybe the correct case just a luck.
and why the solver don't work, I guess the reason is GPU's memory insufficient
I'm so apologize for lose you time.
iGou
==== below is original text ===========================
I just tried use openCL to increase pyroFX speed and got a strange problem
I have tow card Quadro600 and GTX560ti.
if install tow card on MB at same time, openCL will increase performance very much. But if install single card pyroFX's result will be strange and got message “OpenCL Exception: clEnqueueNDRangeKernel (-4)”
here is vedio show the resoult, grid is 233*333*233
http://www.youtube.com/watch?v=Y4JFHBd8pws&feature=youtu.be [youtube.com]
it seen solver can work correctly. after reinstall tow card than it be correctly again.
If decrease resolution to 100^, this time single card can work, too.
Is Q600 and GTX560ti too low level? any one has idea?
thank you!
I don't quite understand the problem you're describing, but here's some infromation about Houdini's system requirements:
http://www.sidefx.com/index.php?option=com_content&task=view&id=415 [sidefx.com]
Be sure you're running the latest Nvidia drivers and developer libraries:
https://developer.nvidia.com/cuda-downloads [developer.nvidia.com]
https://developer.nvidia.com/opencl [developer.nvidia.com]
Hi, Chronon
apology for my pool english. and I noticed my problem is just a mistake.
thank you
