Hello
Windows 7 64 SP1
I5-2400 @ 3.10GHZ
4GB ram
behind a proxy that requires authentication
I installed Houdini Apprentice and got the licence via the sidefx site because Houdini coudn't get it directly from internet.
When I launch Houdini I get this in the console :
Exception in thread Thread-1:
File “D:\soft\Houdini12\python26\lib\threading.py”, line 525, in __bootstrap_inner
self.run()
File “Dsoft/Houdini12/houdini/python2.6libs\hou.py”, line 37370, in __threadRun
self.__run()
File “D:\soft\Houdini12\python26\lib\threading.py”, line 477, in run
self.__target(*self.__args, **self.__kwargs)
File “Dsoft/Houdini12/houdini/python2.6libs\hdefereval.py”, line 141, in <lambda>
thread = threading.Thread(target=lambda: function(*args, **kwargs))
File “Dsoft/Houdini12/houdini/python2.6libs\hdefereval.py”, line 161, in thread_code
it.next()
File “Dsoft/Houdini12/houdini/python2.6libs\sas\localassets.py”, line 238, in check_for_asset_updates
raise e
URLError: <urlopen error getaddrinfo failed>
Then when I create a cube ans hit enter to place it in the center I get this :
3696: Fatal error: Segmentation Fault
Saving application data to cusers/rthriller/AppData/Local/Temp/crash.untitled.rthriller_3696.hip
Houdini crashes.
Any help is welcome.
Houdini crash immediately aftter launch
4363 2 0- rthriller
- 1 posts
- edward
- 7871 posts
- carstenk
- 84 posts
I can't help with the crash, but I think the initial error messages you are getting are not directly connected to this issue. I do get the same errors when behind a proxy - I assume it's Houdini trying to synchronize the assets from the orbolt store. I don't get these error messages when the computer has direct access to the net.
I have not seen any crashes related to the issue on my side.
cheers, carsten
cheers, carsten
carsten kolve - ds @ image engine
