helix on deformed curve
   Views 5801   Replies 4   Subscribers 1
i created a simple helix (cos on X and sin on Z) like the curve 1 on the picture.
i made the deformed one (3 on the picture) with a wire deformer.
I woul like to know if there is a way to do an helix around a deformed curve directly in vop (without using a wire deformer)
thank you.
http://vimeo.com/3dsr [vimeo.com]
if you are careful with the orientation of the curve then it's quite straightforward
helix_from_curve.hipnc (97.7 KB)
thank you a lot .
Have a look at the Switch
0 = Equal Twist
1 = Twist per edge
Have a look here:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=30760 [sidefx.com]
if you need an adjustable offset for the twist begin/end
simple_helix.hip (71.8 KB)
If you want a generic deformer to deform any geometry along any curve, you can also use this:
https://www.orbolt.com/asset/animatrix::pathDeform::1.00 [orbolt.com]
