HDK GA_Edge question
   4079   5   2
Hi Everybody,
I was wondering if anybody knows how to check if an edge is valid using HDK. For example in HOM there is this function hou.Geometry.findEdge(Point1,Point2) and it will return a hou.Edge object if the two points create an edge and None if they dont. So it is pretty simple and so far I can't find any equivalent in HDK for this. My first thought was that maybe GA_Detail class has some similar function but it doesnt. And the GA_Edge class has an isValid() function however, it always returns me 1 even if the points does not create an edge.
Does anybody has any recommandation about this?
Ati
GA_Edge::isValid() is a test to ensure both points in the edge are valid points. To test if an edge actually exists with those points you need to use GA_Primitive::hasEdge, along with your target GA_Edge, to test which primitives might have that edge.
Thank you!
By using gdp->getPrimitivesReferencingPoint() I could get all the primitives which connected to either one of the points of my edge, and then iterating over the primitives I am just calling the hasEdge() function. It works perfectly
ati3d
Thank you!
If you'd like a slight optimization, (you might have already done something like this), the primitive has to contain both points, and the results of getPrimitivesReferencingPoint are sorted, so you could do:
// You can keep the arrays outside a loop to save reallocation.
GA_OffsetArray p0primitives;
GA_OffsetArray p1primitives;
GA_OffsetArray edgeprimitives;
getPrimitivesReferencingPoint(p0primitives, edge->p0());
getPrimitivesReferencingPoint(p1primitives, edge->p1());
primitives0.sortedIntersection(p1primitives, edgeprimitives);
// edgeprimitives will *probably* contain zero or two primitives now,
// but you still need to check hasEdge(), because edge could
// refer to, e.g., a diagonal of a quad instead of an actual edge,
// (in which case, edgeprimitives will *probably* contain only one
// primitive).
Oh, this example code is really usefull. As my next step I also wanted to get an easier way to find out which primitives sharing that edge.
Now it is looking like this, and works perfect.
GA_OffsetArray fpPrims;
GA_OffsetArray spPrims;
GA_OffsetArray intersectedPrims;
GA_OffsetArray::const_iterator prim_it;
gdp->getPrimitivesReferencingPoint(fpPrims,*_firstPoint);
gdp->getPrimitivesReferencingPoint(spPrims,*_secondPoint);
fpPrims.sortedIntersection(spPrims,intersectedPrims);
//std::cout<<“Neighbour primitives:”<<std::endl;
GA_Edge edge(*_firstPoint,*_secondPoint);
int validEdge = 0;
if (intersectedPrims.entries() == 2)
for (prim_it = intersectedPrims.begin(); !prim_it.atEnd(); ++prim_it)
std::cout<<“PrimNum : ”<<gdp->primitiveIndex(*prim_it)<<std::endl;
if (gdp->getPrimitiveList().get(gdp->primitiveIndex(*prim_it))->hasEdge(edge) == 1)
validEdge++;
I was also looking into how to get the neighbourpoints of any of my selected point. It works fine, however I am getting the warning that GU_Detail::buildRingZeroPoints(…) are deprected, and so far I couldn't find anything to replace it.
UT_PtrArray<UT_PtrArray<GEO_Point*>*> ringzero;
UT_IntArray ringvalence;
gdp->buildRingZeroPoints(ringzero, &ringvalence);
UT_Array<int> neighbourPointsArray;
int entries;
entries = ringzero->entries();
for (int i = 0; i<entries; i++)
if (gdp->pointIndex(*_secondPoint) != (*ringzero)->getNum())
neighbourPointsArray.append((*ringzero)->getNum());
std::cout<<“NeighbourPoint: ”<<(*ringzero)->getNum()<<std::endl;
ati3d
Careful! The GA_PrimitiveList is accessed by GA_Offset, not GA_Index! It should be:
gdp->getPrimitiveList().get(*prim_it)
The first one will happen to work in most cases, but may crash in cases where some primitives have been deleted in an earlier SOP up the chain.
There should be a non-deprecated version with the signature:
GU_Detail::buildRingZeroPoints(UT_Array<GA_OffsetArray> &ringzero, UT_IntArray *ringvalence);
and the second parameter can be NULL if you don't need the redundant array indicating the lengths of the other arrays. Using that version:
UT_Array<GA_OffsetArray> ringzero;
gdp->buildRingZeroPoints(ringzero, NULL);
GA_Index firstptind = gdp->pointIndex(*_firstPoint);
GA_OffsetArray neighbourPointsArray;
exint entries = ringzero->entries();
for (exint i = 0; i<entries; i++)
if (*_secondPoint != ringzero)
neighbourPointsArray.append(ringzero);
std::cout<<“NeighbourPoint: ”<<(gdp->pointIndex(ringzero))<<std::endl;
