I think houdini hdk c++ lib is colliding with gcc 4.2 c++ lib in OSX..
I had gcc 4.2 which was installed from XCode “Command Line Tool” and tried gcc 4.7 or clang but all of them having same error only when I compile c++ files.
ld: symbol(s) not found for architecture x86_64
collect2: ld returned 1 exit status
and compile command below
gcc -o test test.cpp
Just created this simple code for this test below won't compile.
#include <iostream>
int main(){
std::cout << “SAO” << std::endl;
return 0;
if I use only c syntax, it works. but c++ syntax no work…
Using Mac OSX Lion, installed Xcode command line tool for gcc4.2.
Please Help me.
Houdini HDK Library colliding with gcc /clang ? in OSX
2443 1 0- Jae hyun yoo
- 1 posts
- alexwheezy
- 318 posts
