Poly
8791 6 1-
- Murciallogo
- 4 posts
- circusmonkey
- 2624 posts
- houdiniWannabe
- 16 posts
Instead of modeling with polys, try modeling with 3D Coat http://3d-coat.com/ [3d-coat.com] or zBrush http://pixologic.com/ [pixologic.com] (many use both together as they tend to leapfrog each in specific features. (3D Coat for surfacing and UVs, zBrush for retopology, both have unique advantages for modeling).
Works for both characters and hard-surface modeling.
Then retopologize using zRemesher (zBrush is the winner at the moment, but 3D Coat is currently working on a new beta that should close the gap).
If you happen to be modeling architecture, then LWCAD on Lightwave http://www.wtools3d.com/ [wtools3d.com] or the port of LWCAD to 3ds Max http://www.futurarch.com/ [futurarch.com] is the way to go.
- anon_user_37409885
- 4189 posts
- Siavash Tehrani
- 732 posts
For the most part I like Houdini for hard surface stuff. It helps to set shortcuts. I have all my most used operations bound to extra buttons on my mouse.
![](http://img.photobucket.com/albums/v123/DaJuice/rf_bottom.png)
But yes, modeling is neglected. Not so much the operators, but the workflow. The problem is, few (very very few?) people use Houdini for traditional modeling. Which means SESI doesn't get much feedback, and there is probably not much pressure from their customers to improve the software on that front, compared to the vfx tools.
Works for both characters and hard-surface modeling.Hmm, idunno. A lot of the hard surface stuff I've seen from sculpting apps looks like it suffers to some degree from blobs-with-creases syndrome.
- houdiniWannabe
- 16 posts
DaJuiceI think I know what you mean.
…Works for both characters and hard-surface modeling.Hmm, idunno. A lot of the hard surface stuff I've seen from sculpting apps looks like it suffers to some degree from blobs-with-creases syndrome.
Probably depends on the skill of the artist? BTW - nice laptop you did in Houdini!!
Here's some smooth hard surface tutorials for zBrush.
http://pixologic.com/zclassroom/homeroom/lesson/panel-loops/ [pixologic.com]
http://pixologic.com/zclassroom/homeroom/lesson/vehicle-design/ [pixologic.com]
and here is a speed sculpt of ‘blobs-with-creases’ in zBrush
http://www.youtube.com/watch?v=_zLuSgT3YyY [youtube.com]
- Murciallogo
- 4 posts
