Multiple levels of instancing.
   2554   1   1
I am trying to figure out how to perform a multiple level point instancing (if it is possible with the current Houdini versions).
Basically:
disk file (a chunk for example) -> instanced on the first set of points (a particle simulation for example) -> instanced on second set of points (a grid layout for example)
On both levels, I need to have control on the transformation and access to the point attributes through cvex. I have tried bits and pieces with only one level. And obviously it all works. Manipulating “Xform” etc. But once I try to make a second level of instancing it all gets a bit confusing.
Any ideas?
Thanks.
Live life in chunks.
Look at this video :
https://vimeo.com/77116364 [vimeo.com]
In this video i made 2 different Copy instancing (or different levels) and animations.
1.at the first level we have a little boxes that make big boxes
2.at the second level the big boxes make extra large box
To make this you can use Cd (Point's Color) to define 2 different animations and levels.
I used Red color with attrTransfer SOP (with distance threshould and Blend Width) to define animation of the First Level (little boxes make big boxes).
And I used GREEN color to define animation of the second level (big boxes make final big box)
I made a very simple project about this method and you can download it.
Of course you can find too many ways to do that like using TimeShift node.
Time Shift method :
Create an animation for make a single box with pieces and append TimeShift node for it..
copy this animation to grid's points and make random value for TimeShift per copy with stamp function.
JKMultiLevelInstancing.hip (173.0 KB)
Rabiee.Sadjad@Gmail.Com
