[HDK] How to display message?
   3652   5   0
There is a routine for python - http://www.sidefx.com/docs/hdk11.0/hdk_soho_examples.html#HDK_SOHO_Examples_Hello2 [sidefx.com]
hou.ui.displayMessage()
however this:
HOM_Module &hou = HOM();
hou.ui().displayMessage(“test”);
doesn't work in C++.
Is it possible to print something in the way like python ones in HDK 11?
up
iDev
up
I've modified the HOM example [sidefx.com] from the toolkit source to display a message.
You need to include <HOM/HOM_ui.h>
Then, just call:
hou.ui().displayMessage(“Hello world”);
Little known fact, there's a C++ interface for HOM too.
SOP_HOMWave.C (3.9 KB)
Hello, mark. In my first message i wrote:
iDev
however this:
It just crashes. Maybe it works in HDK 13, but not in HDK 11.1
iDev
iDev
however this:
Works for me in H11.1.388
Does the HOM SOP work without the modifications? It might be something else in your environment.
I've found that the use of `hou.ui().displayMessage()` can crash when called from a `DM_SceneRenderHook` render function.
