How to output points coloring maps?
   2543   4   1
Hi teacher.
I have a Question.The information can be output point colored textures it and match UV.Such as Burning objects it change black.Thanks.
Oh Man !
I don't know what do you want to do exactly :?
Can you explain it more clearly ?
If you wanna use texture's data match to UV in the point's color ,So you have many ways :
1.Use “Color Map” node in the VEX netwrok.
2.Use tex and texi expression
3.Use pic expression to read image data from Comp network 8)
for example you can create animated texture (Wood changed to black) in the Comp network and assign this texture to lumber model !
Rabiee.Sadjad@Gmail.Com
Joker386
Oh Man !
