wren
   3272   1   1
Hey,
I'm trying to get the output of houdini wren ROP back into houdini as curves.
I can render an image fine but I want curve geo.
Can export what looks like an eps file by playing with the wren export options but it errors when I read it back into Houdini using a file node.
Can anyone help?
On further investigation, turns out wren exports .ps files that need to be converted to .eps.
Apparently there is command line software out there that will do it (ghostscript)
Sounded like a pain though..so I ended up using a trace and fusing with snap average position option on. I cleaned up the geo a bit further from there.
Just making a note in case this is useful to someone else…
