Gas Sand force micro solver
   4598   3   1
Hi friends,
Does anyone know how Gas Sand force microsolver should be used??
I have attached it to the flip solver and particle fluid solver but I have not seen any change.
I really appreciate any help you can provide.
Hi and happy new year,
You can use sand solver by unhide some node in text editor :
opunhide Dop sandsolver
opunhide Dop sandobject
opunhide Dop sandcofigureobject
Just plug all together and sim.
Any way i dont understand why this node is hided by default and not the gas sand.
I m pretty interested to know if there is away to use this gas with flip which will be faster ( i presume)
http://www.papicrunch.net/GC-houdb/ [papicrunch.net]
Hi papi,
Happy new year
The Sand Solver is an interesting tool. However, the simulation is very similar to the flip solver. I am interested in using gas sand force along with flip solver because the help for this node says:
“The fluid is then broken into a series of rigid components whose strain is insufficient to separate the grains of sand. These components velocities are projected to be rigid.”
I want to use this ability for making something like a snow impact simulation…. I have used sand solver but the result is way different…
Its tricky
here is a thread on integrateing strain forces with FLIP, you pretty much have to do the same with sand. I rand some tests and it was too great of results.
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=25343&postdays=0&postorder=asc&start=0 [sidefx.com]
might be a good start
