import attribute vop with multiple component attributes
   2741   4   0
How do I get at specific components of an attribute via the import attribute vop?
For example, if I have a multi component integer attribute, say with 4 components, how do I access the second, third and fourth components? I don't see anyway of grabbing anything but the first component on the import attribute vop.
I tried specifying it as a data type that would expect multiple components, but this didn't work either..
Use Get {x} Component VOPs or {x} to Float VOPs, where {x} can be Vector/Matrix/…
What if you have an attribute which does not fit one of these data types though?
For example a 6 component integer attribute, and I want to grab the fifth component via the import attribute vop?
You can't … in VOPs.
You can only have arrays in VEX currently.
I see. :evil:
