Butterfly flocking system
6498 5 3- fernansha
- 12 posts
Hi everyone
I am experimenting on a butterfly flocking system, where i was inspired from , OZ the great and powerful where Franco falls from the sky and wonders the Beautiful nature among him and sees a bunch of butterfly(which actually looks like a tree) and flies away.
I am almost there and I need some help no to get this up and running
I created and simple model and animated it using chops and cycled it all the way,
and scatterd some points in a surface and copied it over
and i have used a stamp function on a time shift to randomly make the Wings flap over time, so that all the butterfly looks different (has a different look),
and gave the points some force and it moves fine..
now i am stuck with the wings animation, basically i want to take control over the wings flapping, i.e I want the wings to get flapped when the butterfly is flying and not while resting .
This s where i need your help, i tried and i am still trying, and learning to get this done.
any help would be much appreciated.
I have also attached a file, so far what i have and also for people who doesn't understand my broken English
thanks in advance
thanks in advance
Edited by - Jan. 18, 2014 11:25:19
Pepe - nansha
- Sadjad Rabiee
- 1391 posts
I think one of the simple ways is to use AttribTransfer SOP.
for example you can assign RED color to the basic points(Particles system) and BLACK color to the Tree.
At the next step Transfer Color attribute from Tree to the particles with some little “Distance Threshold” and “Blend Width” value.
So color value for each particles that comes close to the Tree changed smoothly from RED to BLACK.
At the last step you can use this color Attr (Cd) in the stamp function in the Copy SOP.
Finally use this stamp function to change animation of the butterflies from flapping to not flapping.
To achieve this Maybe you can use Blend Shapes ,use stamp function in the Blend Shape bias for changing animation from flapping to rest (not flapping) :?
- fernansha
- 12 posts
This is what i have done, but for the particles so it flocks randomly!
Pls chk the file,
its a good idea to use a blend shape! i am giving it a try, its taking some time to get it right!
mean while pls chk the file and tell me what mistake i have done till now
THe file requires and obj, whic i forgot to attach earlier !
so here is it now
Pls chk the file,
so here is it now
Pepe - nansha
- fernansha
- 12 posts
- Sadjad Rabiee
- 1391 posts
- fernansha
- 12 posts
