im doing the candle tutorial, but i ran into some problem in the beginning
of part2. when i add a ADD sop and enter this expression
centroid(“../Top_curve”,D_X)
centroid(“../Top_curve”,D_Y)
centroid(“../Top_curve”,D_Z)
i get 0,0,0
i should get 0.0,847042.0
meaning that Y should be at hte top of the curve.
can anyone help me out
candle tutorial problems
10120 12 1- den myos
- 8 posts
- Simon
- 2199 posts
Sorry I haven't done this tutorial but try changing the expression to
centroid(“../Top_curve”,0)
centroid(“../Top_curve”,1)
centroid(“../Top_curve”,2)
Also, might be worth looking at the spreadsheet for the add sop, RMB menu, and just double check that the point isn't actually where you think it should be. Sometimes expressions show 0,0,0 but they have actually evaluated.
- den myos
- 8 posts
http://sidefx.vislab.usyd.edu.au/houdini_video/by_topic/general/index.html [sidefx.vislab.usyd.edu.au]
here is the link if u wanna try the tutorial, or u can just downlaod the first 2 video. so u can see what im talking about.
mvh den
mvh den
- Simon
- 2199 posts
- den myos
- 8 posts
no. didnt help. i have a feeling that it has something to do with the way the ADD SOP, is added.
the tutorial clearly says bring in a ADD sop, but do not wire it with the top_curve. so i use TAB to bring in the ADD sop.
but is their another way to do it.
im a newbie at houdini
and i need help from anybody who did this tutorial, and made it work.
mvh den
mvh den
- stevenong
- 1634 posts
Hi den,
I think Simon is right. You probably did not type the expression correctly. Houdini is case sensitive so the “c” must also be uppercase.centroid(“../Top_Curve”,D_X)
centroid(“../Top_Curve”,D_Y)
centroid(“../Top_Curve”,D_Z)
If you did type the expressions correctly, the next thing to do is to check the values of the Top_Curve. MMB on the Top_Curve Carve SOP & see if the “Center:” values are what they are supposed to be. If the values in the pop-up info window do not match the tutorial, you probably did a step wrong.
Cheers!
steven
Cheers!
steven
- muttoab
- 10 posts
den myos,
Make sure that your Top_curve carve sop is setup correctly - only firstv should be enabled and it should be at 0. Extract should be enabled.
Similar to what has been previously been say - make sure that you have spelled top_curve correctly in the centroid formula - but most importantly make sure that it is spelled the way you named your carve sop. (If you didn't rename the carve it will still be carve1)
MUTTOAB
MUTTOAB
- den myos
- 8 posts
http://hjem.tele2adsl.dk/aggromax/ [hjem.tele2adsl.dk]
i have put up the candle file for download, so please “save target as”
and see what the heck i missing. ive check all the response but nothing help.
mvh den
mvh den
- puma.snyder
- 121 posts
- den myos
- 8 posts
you were absolutly right, u all were.
it was a type O. but when i change the expression X,Y turn out right, but Z
gave me the number -1.11759e-008. cant figure out what that is connect to, since i should be 0.
i really sorry but im a real newbie to houdini.
u can ask me anything about 3dsmax though.
mvh den
mvh den
- stevenong
- 1634 posts
- den myos
- 8 posts
- asnowcappedromance
- 512 posts
