houdini installation error (gfont) on window7
   1710   1   0
Hi, when I installed houdini. It does not go futher after gfont process is turned on. I turned that process so installation is done.
But when I try open any houdini program. It doesn't work. (houdini command line also stopped right after the window open.)
I tried (as edward's direction) gfont -Sv command. but It doesn't show anything and stuck.
I reinstalled my graphic card driver. still no luck.
Any information about it? Should I format and reinstall window7???
Thank you in advance.
Do you have Windows 7 SP1 installed and all security patches updated to latest?
