Velocity attribute from POPs into SOPs (without Copy SOP)
   3226   1   2
Hi guys!
This should be a really easy question for you guys … I would like to render with velocity attribute blur (i am feeding a popnet into a primitive SOP) - using a copySOP it's easy to transfer the attributes from the popnet .. but how do I transfer the velocity attribute witthout using this method?
cheers,
jostein.
can you use the attribCopySOP?
the attribute has to be somewhere first, plus you need “like” geometry.
You can always use the trailSOP to create the attribute as well.
-k
