Hello.
Recently moved from Softimage to Houdini. I have relatively a little knowledge about ICE. At this time I'm trying to repeat this simple ICE tutorial in Houdini (http://www.youtube.com/watch?v=0c1i498va44 [youtube.com]). And I can't understand where do I start. Where nodes GetData and SetData, which are fundamental in ICE? Explain to me please, an example of this lesson, how to construct the logic in Houdini.
With respect, WotS.
ICE logic to Houdini
12959 18 3- WotS
- 8 posts
- Tom Kleinenberg
- 11 posts
- pezetko
- 392 posts
http://www.sidefx.com/index.php?option=com_content&task=view&id=2186&Itemid=361 [sidefx.com]
and
http://www.sidefx.com/index.php?option=com_content&task=view&id=1744&Itemid=254 [sidefx.com]
First Steps Intro is good way how to get into Houdini workflow.
and
- Netvudu
- 304 posts
I was in a good mood and created a Houdini file which very closely resembles every step taken in that ICE tutorial. It´s also full of notes so that you can go reading along while you see what I´ve done.
I will just say that from your questions (both Wots and Tom) I can tell you currently know very little of Houdini and that worries me. I mean, would you start a novice of Softimage on ICE for his first day with the software? Probably not. It looks like that´s what you´re trying in Houdini. Please, first understand the software and play around.
Anyway, here´s the file for your own pace of learning. This is “VOPs Concepts and Workflows Part 1”
Hope it helps.
Hope it helps.
Javier Meroño
FX TD.
FX TD.
- Tom Kleinenberg
- 11 posts
- WotS
- 8 posts
Thanks for quick help guys! Thank you very much for the links to tutorials. Especially, thank you for sending the project, Javier. But I have one question: in node called “importattrib1” we specify attribute called ‘dist’, but where we recorded it? As I understand it, we find it from the node ‘ray1’, but I not found a function that would write attributes. Or ‘dist’ is I system variable?
- anon_user_37409885
- 4189 posts
- Gyroscope
- 75 posts
WotS
On the importattrib1 Node there is a parameter named OP Input Index. This is set to 1. This will inherit any attribute specified connected to the VOPSOP's 2nd input connector. 0 being first, etc. This input is connected to the Ray1 node, which if you middle mouse click on, will show a pop up with the created dist attribute.
Edit: To open up the Middle Mouse information into a new window, hit the “i” icon (Operator Info) on the node parameters. Next to help, which is pretty extensive with example files.
Edited by - March 9, 2014 15:26:05
- WotS
- 8 posts
- 4189 posts
- Netvudu
- 304 posts
Indeed. The distance is calculated on the Ray Node. If you look its parameter, you will see there´s an option called “Point intersection distance” that is checked. That´s where we are calculating the distance.
And of course, as mentioned, with the middle mouse button you can tell all the attributes that there are at any given point in the network view.
You can also use the spreadsheet over any node to check the numeric values of an attribute at any moment during the node chain.
Javier Meroño
FX TD.
FX TD.
- WotS
- 8 posts
- Netvudu
- 304 posts
uh? the help is inside the program. And it´s really good. You have a help card for every node with examples.
you can also check it online, of course.
http://lmgtfy.com/?q=houdini+13.0 [lmgtfy.com]
Javier Meroño
FX TD.
FX TD.
- WotS
- 8 posts
- Netvudu
- 304 posts
ah, I see.
I don´t think there´s a pdf version of the help.
I imagine you can copy your “help” folder from the Houdini installation into your tablet and read from the browser.
Houdini´s help system shouldn´t be underestimated. It´s a really interactive help with lots of examples. I recommend using it all the time while learning what nodes do.
Javier Meroño
FX TD.
FX TD.
- WotS
- 8 posts
- robonilla
- 84 posts
Hi WotS,
I was wondering, since you said yourself you had little knowledge about ICE, why are you trying to learn Houdini from ICE concepts? Wouldn´t it be better to follow VOPs or other Houdini tutorials for that purpose? There are tons of free and paid tutorials for that matter.
I would understand if you were already familiar with ICE workflow and were trying to replicate your knowledge in Houdini, but since that´s not the case I´m curious why you were doing it like that.
- ctedin
- 69 posts
- Chrizto
- 66 posts
I just wanted to remind people coming from other packages, especially XSI that are used to ICE nodes (also used it for a while) that in some senses the “VEX Builder” networks in Houdini might “look” more complicated, and let's face it, they are because of their general approach to doing things.
This is actually a good thing though. You can use the same brain cells in many more contexts without remembering all the node names for example.
If you want to ease the transition you can turn on the option to display full names for input and output connections in your network views.
You'll get the parameter default variable name by hoovering over a connection arrow anyway, so you can use that in your expressions etc.
Then they will look like this:
“If your life is not NOW, you're already dead…”
From Chrizto's book of truths
