In “Edit parameter interface” We can create “Multi-line String”, but I can not find how I can achieve it in python??
I read the api, find this attribute,but I don't know how to set it.
http://www.sidefx.com/docs/houdini13.0/hom/hou/StringParmTemplate [sidefx.com]
itemGeneratorScript(self) → str
Return the script used to generate menu items, or an empty string if there is no such script.
This script is used when this parm template uses a menu.
Note that if the item generator script language is hou.scriptLanguage.Python, this script may be either a single-line Python expression or a multi-line body of a Python function.
thanks
python Multi-line String
7708 3 1- 达 风
- 7 posts
- edward
- 7903 posts
- nilth
- 2 posts
For everyone who find this old topic (like me), to create a multiline string parameter. You have to modify the key “editor” value to 1.
import hou node = hou.node('/obj').createNode('geo') group = node.parmTemplateGroup() folder = hou.FolderParmTemplate('folder', 'My Parms') template = hou.StringParmTemplate('myparm', 'My Parm',1) template.setTags({"editor": "1"}) #it's "0" by default folder.addParmTemplate(template) group.append(folder) node.setParmTemplateGroup(group)
Edited by nilth - May 5, 2017 13:37:54
- Petfactory
- 18 posts
Thank you for this. It pointed me in the right direction.
If you want a multiline string param to use Python:
If you want to inspect a node the asCode function is really nice.
To write it to a file we can execute snippet below in the python shell
...setTags({"editor": "1", "editorlang": "python"})
with open('/path/to/somewhere/as_code.py', 'w') as f: f.write(hou.node('obj/geo1/your_node').asCode())
