RBD Object Stopped
   3010   2   1
HI
I often meet this problem.
The RBD Object accidently stopped after some frames in simulation.
In this attached hip file , It stopped after 50 frame.
I use H13.0376. What's the reason ?
rbd_sim.hipnc (211.0 KB)
You can turn off “Enable Sleeping” on the RBD Object under the “Collisions/Bullet Data” tab. Otherwise, the solver tries to deactivate objects that are not moving or interacting with anything in order to improve performance.
It's ok. Thank you very much!
