RBD packed object with inherit velocity from point velocity turned on and @active controlling when a object is actively turned on in DOPs .
I am wondering why I get initial movement on frame 1 from V being set on the rbd packed prim objects, when no object is actually active ? . I don't mind setting V in the wrangle dop with the sop data . I just want to know why I would get initial movement with no active objects.
rob
set point velocity + RBD packed object
5811 1 1- circusmonkey
- 2624 posts
- cwhite
- 748 posts
