mplay - not saving settings
   3287   1   0
Using mplay from 6.1.109 …
when I change the settings (specifically the Frame Rate), it is not saved. Is this a problem amd/or where does it save the settings?
Thanks in advance
Rob
Digital Supervisor | Stargate Studios Toronto
try this, go to your settings menu and choose Profiles.
In the profile window you'll see that there is a field called “command line”.
by entering options in this field, and clicking save, you can save these options as preferences.
type mplay - for a full list of options.
As an example, if you want to set your frame rate to 24 fps type the following in the command line field:
-r 24
cheers
Luca
