BUG in the measure node.??
3922 8 1- Eric Ebling
- 5 posts
HI, learning houdini and not sure if this is a bug or me doing something wrong. I am using the measure node and having it get the area of the primitives of a torus. if I leave the attribute name to the default of “area”, I can then use a delete node after the measure node and type this “$AREA<.2” using delete by expression and it deletes the primitives correctly that have an area less than .2. If in the measure node I click the Override name button, and enter my own name, say “eric” and then type this “$ERIC<.2” into the delete expression, it gives me an error and does not work.?! It seems no matter what name I use as an override, that attribute is not useable. As a test, I put an attribCreate node after the measure node, made an attribute named “eric”, then assigned the values out of $AREA to the attribute value of eric, and then when I used “$ERIC<.2” in the delete expression it worked fine. So am I missing something here.? Or is this a bug when you try overriding the area attribute name to something custom.? One thing I notice when I middle click on the attribCreate node, it gives me a Custom Varible Mappings with eric -> ERIC. Any help is appreciated. I have just started, once again, doing some houdini tutorials… Oh and this is in H13.
- anon_user_37409885
- 4189 posts
- Eric Ebling
- 5 posts
Hmm I figured if the measure node had the option to create a variable with a different name, then I would only have to check the override box and give it the name I wanted to use. It doesn't make sense why I would have to make my own variable and then transfer the $AREA values into this new variable to then use them with a different name.?? But it does work, so i guess I can do it that way if that is how it is suppose to work.
E.
E.
- 4189 posts
- Eric Ebling
- 5 posts
oh ok, so what would the point be of overriding since the attribute made with the overridden name doesn't seem to be directly accessible.? The tutorial I watched overrode the “area” name to “prim_area”. Is this just so you can make names you prefer or are more easily recognized and then if you want to access the data in it, you need to do the attribCreate thing I mentioned before.? It seems like an extra step since if I just leave the name to the default of “area” then I can directly access this data by way of $AREA….
E
E
- 4189 posts
- Eric Ebling
- 5 posts
- tamte
- 8786 posts
Eric Ebling
E.
first of all Measure Sop is creating an attribute not variable
so to get the variable mapping to custom, nonstandard attribute name you need to use Attribute Create Sop to initialize variable
you can use attribute without creating a variable and I would recommend that as variables are older, slower way to do that. Have a look at the file for comparison
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- Eric Ebling
- 5 posts
