I am trying to use the “match” vex function like this:
i@mymatch = match("obj_",@myattr);
Instead of matching attributes with 10,12,13 values it matches with 1,0,2,3.
What would be the correct way to match decimals?
String matching
9374 6 2- mzigaib
- 966 posts
- fsimerey
- 279 posts
See here
http://www.sidefx.com/docs/houdini13.0/vex/functions/match [sidefx.com]
*z - Match any string beginning with a, b or c and ending with z.
So, try to match 1, 0, 1(but already tested), 2, 1(tested), and 3.
I think you may try with this expression
- tamte
- 8753 posts
you'll need to do
obj_1
for your case, but as houdini's patterns are slightly more limited than regular expressions it may easily happen that you can't create simple pattern covering all the matches you want
so you can just use these rules
http://www.sidefx.com/docs/houdini13.0/expressions/_patterns [sidefx.com]
obj_1
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- mzigaib
- 966 posts
- mzigaib
- 966 posts
Hi guys!
Here I am again with another question regarding matching strings in vex.
What would be in VEX the equivalent to the strreplace() expression?
I want to to change a attribute like:
$HIP/texture/mytexture.jpg to $HIP/texture/mytexture.rat
I would like to to that in a wrangle node is it possible?
- tamte
- 8753 posts
I think that's quite limited with current VEX functions, you could split() the string based on “.” to array, then replace last element with “rat” and than assemble back to string, but that feels like too much work for something that could be done easier
if however replacement of string attribute is what you are after, then have a look at AttributeStringEdit SOP, where you can even use regular expressions for substitutions
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- mzigaib
- 966 posts
