Constraining camera to simulated geometry
   5499   4   1
This may be an easy one but I can't seem to figure out a way to rigidly constrain a camera to a simulated object. I need to do a POV shot off one of the RBD simulations. Is there a way of finding out it's world space coordinates Post-Sim?
Thanks in advance!
Well, you can use rivet to parent an OBJ level node to a geo point.
ee_cam_fracture_parent.hip (316.1 KB)
So that's how you use it. Love learning the nuance of all these new Houdini tools
New problem. I can use rivets to connect the camera and constrain the camera's rotation by using another rivet. However, due to the way that Houdini wants to have the camera have a relationship to an “up” orientation I'm having difficulty figuring out a way to keep the camera from constantly trying to “roll” when it is supposed to be hard mounted to the simulation object (POV style).
Any thoughts?
Add a Polyframe SOP, and in the DOP Import SOP add “up” to the “N” already present in the Vector Attributes To Transform parameter.
I guess adding the Polyframe after the DOP Import would work too.
ee_cam_fracture_parent2.hip (318.0 KB)
