Get the bounding box of an Alembic Archive
   Views 4887   Replies 5   Subscribers 0
He,
Alembic archives don't have any geometry class, they are like a subnet, so there is not bounding box data attached to them. Is there a way to get the bounding box of all the alembics nested in an alembic archive?
Ta,
Nick
hi!
import the alembic in SOPs, switch to Load as Houdini geo, and append a bound SOP.
daniel bukovec | senior fx td | weta digital
qLib -- http://qlab.github.io/qLib/ [qlab.github.io]
buki
hi!
Even better, load as Alembic primitives. Then, only the Alembic bounding box will be loaded (not the full geometry). You can even set the display to be bounding box only.
Hey,
This is for lighting, so we can't use sops, the scene will have crawl. Has to be an alembic archive.
I need to query ONLY the alembic archive, not the alembic nodes it creates. Must be a way
Nick Deboar
Hey,
How will the scene crawl loading a bounding box ? If you have lots of objects just load all the primitives in and put a bound round them.
Rob
Gone fishing
@Nick
did you get anywhere with this?
Training Lead
www.sidefx.com
