Amazon cloud render (Indie)
   4030   6   2
Hello Guys,
I am experiencing problems with cloud rendering. Have anybody achieved it?)
I went through manual and understand that everything should be in one ($HIP) folder. So I put my geometries, assets to one folder. After I upload it successfully on amazon I have receive “failed” without any explanation
Maybe it is this parameters in File dependencies? But I moved everything. Other things can not be moved by just dragging it.
I would be very thankful if you help me with this issue.
logfile
2014-09-01 22:39:21,050 INFO: Registering ‘igorbackstrom_RoomAnimation’ with the cloudmonitor daemon.
2014-09-01 22:39:21,140 INFO: RPC: “GET /spinner.gif HTTP/1.1” 200 -
2014-09-01 22:39:21,316 INFO: RPC: “GET / HTTP/1.1” 200 -
2014-09-01 22:39:21,331 INFO: RPC: “GET /cloudsubmit.css HTTP/1.1” 200 -
2014-09-01 22:39:21,333 INFO: RPC: “GET /jquery-1.3.2.js HTTP/1.1” 200 -
2014-09-01 22:39:21,335 INFO: RPC: “GET /jsonrpc.js HTTP/1.1” 200 -
2014-09-01 22:39:21,337 INFO: RPC: “GET /json2.js HTTP/1.1” 200 -
2014-09-01 22:39:21,338 INFO: RPC: “GET /cloudheader.js HTTP/1.1” 200 -
2014-09-01 22:39:21,339 INFO: RPC: “GET /cloudsubmit.js HTTP/1.1” 200 -
2014-09-01 22:39:21,403 INFO: RPC: “GET /cloud_header_background.png HTTP/1.1” 200 -
2014-09-01 22:39:21,404 INFO: RPC: “GET /cloud_close_button.png HTTP/1.1” 200 -
2014-09-01 22:39:21,405 INFO: RPC: “GET /cloud_terminated.png HTTP/1.1” 200 -
2014-09-01 22:39:21,458 INFO: RPC: “GET /thinking_cloud.gif HTTP/1.1” 200 -
2014-09-01 22:39:21,459 INFO: RPC: “GET /houdini_icon.png HTTP/1.1” 200 -
2014-09-01 22:39:21,466 INFO: RPC: “GET /cloud_terminate_button.png HTTP/1.1” 200 -
2014-09-01 22:39:21,467 INFO: RPC: “GET /cloud_scroll_right.png HTTP/1.1” 200 -
2014-09-01 22:39:21,468 INFO: RPC: “GET /cloud_scroll_left.png HTTP/1.1” 200 -
2014-09-01 22:39:23,625 INFO: RPC: “GET /cloud_selected_job_divider.png HTTP/1.1” 200 -
2014-09-01 22:39:23,627 INFO: RPC: “GET /cloud_no_progress.png HTTP/1.1” 200 -
2014-09-01 22:39:23,629 INFO: RPC: “GET /cloud_progress.png HTTP/1.1” 200 -
2014-09-01 22:39:23,630 INFO: RPC: “GET /cloud_play_button.png HTTP/1.1” 200 -
2014-09-01 22:39:23,637 INFO: RPC: “GET /cloud_selected_job_background.png HTTP/1.1” 200 -
2014-09-01 22:39:27,817 INFO: Pinging cloud server.
2014-09-01 22:39:32,322 INFO: RPC: “GET /spinner.gif HTTP/1.1” 200 -
2014-09-01 22:39:46,303 INFO: Pinging cloud server.
2014-09-01 22:40:04,170 INFO: Pinging cloud server.
2014-09-01 22:40:07,637 INFO: Unregistering ‘igorbackstrom_RoomAnimation’ from the cloudmonitor daemon.
2014-09-01 22:40:23,860 INFO: Pinging cloud server.
2014-09-01 22:40:41,475 INFO: Pinging cloud server.
2014-09-01 22:41:00,602 INFO: Pinging cloud server.
2014-09-01 22:41:17,917 INFO: Pinging cloud server.
BR
Igor
I worked with Hqueue a lot and the way it wanted to work was with $HIP also but everything the scene read was with $HIP also, so if we were using a cache it would be under the scene folder which is $HIP right so, we would read the caches as $HIP/geo/cache_$F4.bgeo for example. and for rendering file path again set with $HIP instead of absolute path
Head of CG @ MPC
CG Supervisor/ Sr. FX TD /
www.timucinozger.com
tricecold
Thank you! But I already puted $HIP instead of actual pass (geo, assets, render file).
And what should I do with other red items?
HQROOT
server2
${OS}_SSS.pic
IFD.py
'strcat
temp:
It seems like you are using some PTC, change their path to a folder under $HIP. Because by default SSS ptc is created under temp folder of the system, so point that to a folder under $HIP
also it seems like it has a problem finding maybe surfer_color.jpg , replace all the files/textures/caches with $HIP addreses instead of absolute paths if you havent already.
These were the rules for Hqueue in my last studio, but these rules can be wildy customized. So Sidefx would be able to give you much accurate answers.
Head of CG @ MPC
I don't know if it is right but can you please explain this points in detail.
What is PTC? Particles? I did not use them. May be they was in asset. But after I just exported geometry and asset was not involved further in project. Or if they are, where I can change path?
Where I can point it?
I have studied shop and there were no fill form for path. Where I can find it?
Sorry, but I am trying to figure everything out and without anybody it is quite complicated.
well on the screenshot you provided there are some red fonts, I am assuming these are not good.
pc is a point cloud it may be created by a mantra surface shader under subsurface/point Cloud tab.
there you will see a place written excatly ${OS}_SSS.pc well you can change this to begin with to a folder under $HIP ( if you have subsurface activated, otherwise I have no idea)
Surfer_color.jpg , if you did not assign this to a shader from an input area from the parameters section, maybe someone else put it directly inside the shader. You can double click on the shader to dive inside to see if its loaded internally.
One last thing is , you say you use assets, so you may need to get into the asset as the shopnet could be in the asset.
Good luck
Head of CG @ MPC
I want to retrieve my deep camera map files from amazon instance because only the output images are automatically downloaded but when I ssh into the instance I cannont see any thing other than the houdini versions.
Does anyone know where the files are that are generated?
