Surface Length to Domain parameter
   1913   0   1
Is there a quick way to do an arc length evaluation of a position on the surface - similar to uniform texture coordinate construction (uniformTexture()?)?
At the moment I have to do a workaround by constructing a curve and then using unitLengthToUnitDomain(); for example getting a position using curve u(s) parameter:
float unit_u = curve->unitLengthToUnitDomain(unit_s);
surface->evaluate(unit_u * num_segments, v, pos);
