Apologies if this was answered many moons ago when the decision was made (my searching skills failed me), but why were the GCC 4.1 builds dropped? Was there a technical issue/limitation, or was it “only” an administrative annoyance?
After a long hiatus in building our tech in/for Houdini, we recently discovered to our horror that building plugins using GCC4.1 works, but they crash when actually used (in the GCC4.4-built Houdini 13.5).
Cheers!
- Rob
GCC 4.1 - why dropped?
4625 8 3- rjpieke
- 65 posts
- halfdan
- 599 posts
rjpiekeA mix of both. gcc 4.1 is basically broken, especially when it comes to vector math and templates, both of which we rely on heavily. Coupled with the fact that the number of studios unable to run the gcc 4.4 or higher builds was getting smaller by the day, it's demise was inevitable.
That said, our gcc 4.4. builds are done on a machine that comes pre-installed with gcc 4.1, so there shouldn't be any libc issues (which was the biggest concern, for studios still stuck on gcc 4.1 platforms).
What kind of crashes are you running into?
Halfdan Ingvarsson
Senior Developer
Side Effects Software Inc
Senior Developer
- v2n
- 62 posts
Hi Halfdan
For example, a SOP operator will crash on the first call to a method from GU_Detail/GEO_Detail (like gdp->clearAndDestroy() or GU_PrimPoly::build(gdp, 3, GU_POLY_CLOSED) ).
On the other hand I can build the field3dtools plugin (the one shipped with the houdini toolkit) using gcc4.1.2 and I'm able to load field3d file (using the file node).
So if you are able to build a SOP operator using gcc4.1 let me know !
Guillaume Laforge
Guillaume Laforge
- rjpieke
- 65 posts
- halfdan
- 599 posts
v2n
After a brief discussion with the gang, turns out that my information is slightly off (although gcc 4.1 is still crap). Apparently building with gcc 4.1 and running in gcc 4.4 Houdini will not work reliably.
However, what will work, is to install gcc 4.4, on a gcc 4.1 system, and build with that. The resulting code will still run on gcc 4.1 systems (e.g. CentOS 5), without gcc 4.4 present.
Halfdan Ingvarsson
Senior Developer
Senior Developer
- rjpieke
- 65 posts
- halfdan
- 599 posts
rjpiekeThis is unlikely to happen, unfortunately. We've made too many code changes that are incompatible with gcc 4.1, which would be a lot of work to revert back on. Plus, we'd have to figure out all new bugs again.
Any chance you want to (or don't want to but still can) start building with GCC 4.1 again?
We have a rather massive codebase built in 4.1 which we'd rather not rebuild using 4.4+ just yet.
Isn't everyone jumping on the VFX Reference Platform bandwagon anyway?
Halfdan Ingvarsson
Senior Developer
Senior Developer
- rjpieke
- 65 posts
- halfdan
- 599 posts
