I am trying to figure out how to get a motion blur pass from Houdini to Nuke. Inside the material shader I have this set up as suggested by someone else on the forums (see attachment 1), which is exporting the motion parameter to mantra.
The Mantra render node is exporting the motion pass that it finds on the shader. This seems to be working properly. When I bring it into Nuke the motion blur works but breaks at a certain point, like I can't add more motion blur without it creating this ghosting effect.
Is this the best way to do motion blur in Nuke? I feel it's too expensive on this film I'm working on to do motion blur in render because of the drastic render times.
Motion Blur Houdini Mantra Pass to Nuke VectorBlur
10933 3 2-
- garretthoyos
- 43 posts
- circusmonkey
- 2624 posts
Years ago this used to be the case, now its far easier to render motion blur in camera. using the old motion pass technique would in case look incorrect for certain shots in any case. So its not by any means a fix all solution.By drastic render times what are we talking ?
Rob
Gone fishing
- garretthoyos
- 43 posts
- anon_user_37409885
- 4189 posts
