Very simple use of Connect Adjacent Pieces does not work
   9722   17   2
I'm a bit confused. I've used this tool before and it just worked without any problems. I've started on a new file, which is much simpler, but the connect adjacent pieces node does absolutely nothing.
I'm sure I'm doing something stupid, but I just can't see it.
intercellular.hipnc (93.3 KB)
Hello again,
A bit hard to say what's wrong as I'm not sure what is the exact effect you're aiming for. At least the search radius was a bit low, plus the ForEach is a bit redundant, as each execution loop is identical.
intercellulare.hipnc (93.2 KB)
Hi eetu
It didn't matter what the search radius was, it never connected anything. There's a reason for the for loop too
Yours looks exactly the same as mine
I think I'm having graphics display issues. Some stuff just doesn't show up in the viewport.
I've had that lately as well. Try creating another obj and selecting that, I've seen the selected object disappear lately. Or try opengl 2.1 or rendering.
http://forums.odforce.net/topic/20921-all-geometry-suddenly-appear-transparent-in-the-viewport/ [forums.odforce.net]
Changing to OpenGL 2.1 worked. Seems 3.1 is borked
Thanks eetu!
I spoke too soon. Houdini is just super unstable and crashing constantly, so I can't really do anything
It would be good to submit a bug under the Support menu above.
Will do.
Just out of interest, what is your driver/card combo? (I presume Nvidia)
System Information
Time of this report: 9/28/2014, 20:41:06
Machine name: GALAXY
Operating System: Windows 8.1 Pro 64-bit (6.3, Build 9600) (9600.winblue_gdr.140723-2018)
Language: English (Regional Setting: English)
System Manufacturer: ASUS
System Model: All Series
BIOS: BIOS Date: 09/02/13 19:25:51 Ver: 06.06
Processor: Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz (4 CPUs), ~3.2GHz
Memory: 16384MB RAM
Available OS Memory: 16064MB RAM
Page File: 6280MB used, 12216MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.03.9600.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GTX 760
Manufacturer: NVIDIA
Chip type: GeForce GTX 760
DAC type: Integrated RAMDAC
Device Type: Full Device
Device Key: Enum\PCI\VEN_10DE&DEV_1187&SUBSYS_360B1458&REV_A1
Display Memory: 4033 MB
Dedicated Memory: 1985 MB
Shared Memory: 2048 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: SAMSUNG
Monitor Id: SAM0B30
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 9.18.0013.4411 (English)
Driver Version: 9.18.13.4411
DDI Version: 11
Feature Levels: 11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported
Hybrid Graphics GPU: Not Supported
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 9/14/2014 01:48:03, 19954520 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-52C7-11CF-D366-06161CC2C435}
Vendor ID: 0x10DE
Device ID: 0x1187
SubSys ID: 0x360B1458
Revision ID: 0x00A1
Driver Strong Name:
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Current Mode: 1920 x 1200 (32 bit) (59Hz)
Monitor Name: Dell E248WFP(Digital)
Monitor Model: DELL E248WFP
Monitor Id: DELA02E
Native Mode: 1920 x 1200(p) (59.950Hz)
Output Type: DVI
DDI Version: 11
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x10DE
Device ID: 0x1187
Revision ID: 0x00A1
Sound Devices
Description: SAMSUNG-4 (NVIDIA High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_0040&SUBSYS_1458360B&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: nvhda64v.sys
Driver Version: 1.03.0032.0001 (English)
WHQL Logo'd: Yes
Date and Size: 9/17/2014 06:51:20, 197408 bytes
Other Files:
Driver Provider: NVIDIA Corporation
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX™ 2.0 Listen/Src: No, No
I3DL2™ Listen/Src: No, No
Sensaura™ ZoomFX™: No
Description: Digital Audio (S/PDIF) (High Definition Audio Device)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0887&SUBSYS_10438576&REV_1003
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: HdAudio.sys
Driver Version: 6.03.9600.16384 (English)
WHQL Logo'd: Yes
Date and Size: 8/22/2013 13:38:21, 395776 bytes
Other Files:
Driver Provider: Microsoft
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Microphone (High Definition Audio Device)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Video Capture Devices
Number of Devices: 0
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Dell USB Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x413C, 0x2010
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
I am not sure how to see your driver version in all that text, but I had viewport problems too.
It was because I used the latest 344.11 Drivers from Nvidia which they released with the new 980 cards, so I downgraded to the previous 340.52 drivers and now everything works again.
/M
Personal Houdini test videos, http://vimeo.com/magnusl3d/ [vimeo.com]
Yes, this did start happening when I updated my graphics card on both my work and home machines. I've submitted a bug anyway and the devs have the information, but in the meantime I'm trying to see if there's a way to downgrade my drivers.
Oh, and I'll be trying to achieve an interesting animation effect eetu - and I'm sure to get stuck and post for help, so I'll warn you in advance
Anti-Distinctlyminty
having the same problem… only in the foreach.
Outside the foreach its just working fine….
I have looked your file and it's not update issue. Check on odforce.
I've still got the same behaviour GeForce driver version 344.48
(previous was 344.11)
I just stumbled upon this thread because I encountered the same problem and I know this thread is a few years old.
The problem in my case was that the points were missing a pscale attribute and voila they connected just fine.
Cheers
I don't know if my issue was the same that the OP was encountering, but in case this thread is found by another having the same problem I had…
I was using a Voronoi Fracture node then an Assemble node to create the packed geometry. When I added the Connect Adjacent Pieces node, I was not seeing any connections. I looked back at my Assemble node and saw that my Pivot Location was set to Origin. When I changed it to Centroid, all of the connections then appeared between my pieces.
