I am making an asset with two inputs.
Inside this asset, I have a switch
I want to check if something is connected to the 2nd input and then change the switch value ( from 0 to 1).
I tested this python expression :
node = hou.node('../')
nConn = node.inputConnections()
if len(nConn) == 1 :
return 0
return 1
if the code seems to work I have now an issue because when the second input is non_connected, my asset return an error “ not enough source specified”
How can I make it work ?
Thanks.
HDA and expression issue
2284 3 1- vbk!!!
- 383 posts
- edward
- 7899 posts
- vbk!!!
- 383 posts
- Mohanpugaz
- 146 posts
edwardThat helped me a lot. After few hours of research I found this answer!I was so dumb that I dint see that option which is available on the first tab itself. Thank you so much @Edward.
Make your asset have a lower minimum number of inputs.
Mohan Pugaz
movfx
movfx
