I recently found this amazing resource to preview matcaps materials in the viewport. But unfortunately I cant make it work.
https://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=22724 [sidefx.com]
This first problem is that the pow function is not recognized by Houdini, so what I did was to modify the code and delete everything related to the pow function. (some beautification too :wink: ):
// vertex shader
varying vec3 vPos, vN;
void main() {
vPos = vec3(gl_ModelViewMatrix * gl_Vertex);
vN = normalize (gl_NormalMatrix * gl_Normal);
gl_TexCoord = gl_MultiTexCoord0;
gl_Position = gl_ProjectionMatrix * vec4(vPos, 1.0);
// fragment shader
uniform sampler2D g_smpTex;
uniform int glH_MaterialPass;
varying vec3 vPos;
varying vec3 vN;
void HOUassignOutputs(vec3 emit, vec3 amb, vec3 diff, vec3 spec, float shiny, vec3 P, vec3 N, float alpha);
void main() {
vec3 c;
vec2 uv = normalize(vN) * 0.5 + 0.5;
vec3 n = normalize(vN);
if (glH_MaterialPass == 0) {
c = texture2D(g_smpTex, uv).rgb; // lookup color from normal
HOUassignOutputs(
/* emit */ c,
/* amb */ vec3(0.0),
/* diff */ vec3(0.0),
/* spec */ vec3(0.0),
/* shin */ 0.0,
/* P */ vPos,
/* N */ vN,
/* alpha */ 1.0
} else {
HOUassignOutputs(
/* emit */ vec3(0.0),
/* shin */ 0.0,
/* P */ vPos,
/* N */ vec3(0.0),
/* alpha */ 1.0
I created another parameter for glH_MaterialPass and embedded the otl to the hipnc, just in case
But this doesn't even work for me it's just transparent. I tried to implement it again from scratch in Houdini 13 but not luck (now its Black
So, how can I use this shader in Houdini 13? I'm using AMD by the way.
Also, the Houdini Console is reporting:
Unknown operator type: Shop/GLSL_matcap
Thanks for reading!!
Here is the new file:
