Hello all,
Another revision of the Real Flow plugins are now available, you can download them at:
http://www.digitalcinemaarts.com/dev/real_flow/download.html [digitalcinemaarts.com]
A few new features:
SOP_RF_Export: New “Apply Object Transformations” switch; when checked the transformations made at the OBJ level for the SOP is used to transform the geometry to the Real Flow SD file.
SOP_RF_Import: Now supports multiple objects (up to 255) in a Real Flow SD file. There are 2 new toggles, “Apply Object Transformations” which will apply the SD files object t/r/s vectors to the geomtry and “Apply CG Transformations” which will apply the SD file's CG t/r vectors to the geometry. It appears there's a 90deg rotation about the Y axis for some RBD SD files, you can remedy this by appending a Transform SOP for now, I'll be investigating this more soon.
–Mark
Real Flow plugins v0.98 ready
2170 0 1- xiondebra
- 543 posts
