I have a Multiparm Block (tabs) that allows users to position objects within my Digital Asset. The objects have a fairly large stack of attribs, and I'd like to give the user a visual indication of which object their currently selected tab refers to. Is there any way to read the currently selected multiparm tab?
When dealing with regular (non-multiparm) folders, you can open a Python shell and do:
hou.node('/obj/myhda1').parm('tabfolder').eval()
… and it tells you which (non-multiparm) tab is selected by index.
But, when you call eval() on a multiparm folder parameter, you do not get the index of the currently selected folder. Houdini returns the integer total count of multiparms created.
Seems this question has been asked before [sidefx.com], a couple of years ago, and was never answered. (On the ODForce boards too, [forums.odforce.net] but the replies were all misunderstanding the multiparm block part.) I have the exact same question as that guy. I don't suppose a way of doing this has surfaced since then?
Maybe there is a way to query some hidden GUI element that's responsible for showing the multiparm tabs? Or maybe a fancy way to use callback scripts?
How to find currently selected tab in multiparm folder?
5532 8 4- misterbk
- 20 posts
- edward
- 7899 posts
- misterbk
- 20 posts
- hale38
- 1 posts
- martinkindl83
- 262 posts
- UtilitasArts
- 16 posts
- viklc
- 222 posts
Currently there is no event handling when switching the tab menu and it is also not possible to set a default tab menu. I think they are treated as simple visibility property. A workaround is to create a separate button/toggle as a multi-parm instance which allows to set the current instance manually. You can then store the currently selected state in a separate parameter and read the data elsewhere.
There is an example in the hip file, have a look at the code in the Python module.
- UtilitasArts
- 16 posts
- viklc
- 222 posts
viklcSee: setMultiParmTabInEditors [www.sidefx.com]
