boat wake force
   11362   6   2
Hello guys,
I am working on a shot with a boat wake and have found this nice solution
https://vimeo.com/93243750 [vimeo.com]
Now my goal is too achieve the same result, but I don´t know how to start.
Can you give me some tips?
Edited by - Dec. 13, 2014 22:11:12
wakeforce.hip (1.6 MB)
I think the description about my problem was not good enough.
My goal is not to achieve a boat wake only with collision of the ship, I need more control with custom forces.
The grid is 400* 200 m
Method which are used in the video is exactly this, what I looking for.
But I don´t know how to setup such a custom force with the flip-solver.
You want to use Pumps.
Create some geometry however you want. Create a point attribute of type vector called “v” for velocity.
With your flip fluid already in place, go to the Populate Containers Shelf and with your geometry object with the sculpted velocity attributes selected, press the Pump Shelf tool and follow the prompts to select the geometry and the fluid container.
Now press play and you will see your velocity affect the flip fluid. You will have to tune the scale of the velocity in DOPs to suit.
See the attached hip file.
flip_pump_bow_curl_v001.hip (3.6 MB)
ahhh ok
Thx Jeff! Very informative, I will try it out.
Glad I found this. I had seen that same sample video last week, and spent several days trying to recreate it. I was able to add velocities into the system correctly, but I wasn't able to aim my velocities well at all.
Your sample scene helped me out a lot. Thanks Jeff!
Hi guys, I'm looking for how to achieve a wing shape vel like Mason's project on vimeo: https://vimeo.com/123026523. [vimeo.com] Would you mind to show me a clue? Thanks!
can't anyone help !
Jeff's file is good but it is not acheiving what i want at all
